Bypass Tests
During this procedure, the WatchMon will test every CellMon’s balancing resistors, one by one for a few seconds. You should notice the LED turning ON and the temperature increasing about +/-5 degrees then proceeding to the next CellMon in the chain.
Step 1 - Click on “Bypass Test”
or click on "Menu" then click on "Hardware"
Click on "CellMon" tab and click on "Bypass Tester"
Step 2– Click on “Start”
Testing CellMon number 8
Results after the Bypass Tests
All bypass test results are saved in a folder for future reference
If you see the green "Successful Bypass Test" message you completed the 7 "Setup Check List" and you will now see the information in full screen.
Bypass Tester - Options
Bypass Tester - Progressive
Bypass Tester - Results
