Connecting the ShuntMon to WatchMon4
ShuntMon works with either WatchMon4 and WatchMon1 and typically comes in your starter kit with a cable labelled “yellow”, connect the cables as per photos below:
Follow the picture below as the wiring diagram:
  • Maximum Battery Voltage = 650v DC
  • Current = 500A
Shuntmon can be connected to either WatchMon1 or Watchmon4 using the same wiring sequence:
Connection on Shuntmon
Communication 4 pin port:
Pin Colour Function
1 Red Isolated 5vdc supply
2 Green Isolated TX to WatchMon
3 Yellow Isolated RX from WatchMon
4 Black Isolated Ground
Voltage sense 2 pin port:
Pin Colour Function
1 (spare)
2 Red Battery Positive
Battery Current terminals
Pin Function
LEFT Battery load - to inverter/charger
RIGHT Battery Neg - from cells
Connection on Watchmon
Terminal strip connections are as follows:
Pin Colour Function
12 Red 5vdc supply
13 Green RX from Shunt
14 Yellow TX to Shunt
15 Black Ground
Reference:
Link to ShuntMon product page
Can we use our own Shunt Block?
