Watchmon4 - FAQ and How-to guides
Below are links to the latest evolution of Watchmon4 supervisor. For previous versions such as WatchMon1 or PacMon it is best to follow their relevant procedures.
Installation procedures
Installation steps for the Watchmon4 Toolkit software
Installing USB drivers for Watchmon4 supervisor
Upgrading the Firmware on the Watchmon4 supervisor
How to connect the Cell monitors to WatchMon4 supervisor
Multiple Cell Monitors or "multi string" configuration: adding batteries in parallel to the same WatchMon supervisor
How to connect the Shuntmon2 to Watchmon4 supervisor
Running the Wizard setup to define your system
Verifying the Cell monitors for faults using Network Tester
Troubleshooting CellMon Network for faults - WatchMon4
Synchronising the Cell monitors using Device Sync
Testing Cell monitors balancing resistors with Bypass Tester
Wifi
Connecting to WatchMon4 via Wifi
Wifi troubleshooting
Expansion Board
ExpansionBoard hardware and wiring guide
How to add the Expansion Board to a WatchMon4 - VIDEO
WatchMon4 Hardware
Watchmon4 hardware guide and pin assignment
Understanding Watchmon operating state LED indicator
Coin Battery Replacement - WatchMon Supervisor
CellMon Network - Installation, Test & Troubleshooting
Design considerations for cell monitors
How many LongMons can be installed with one WatchMon?
AutoLevel Bypass (auto-balance) configuration
How to Fix Cell Monitor cables - Video
Understanding the LED Indicators on each CellMon
How to identify a specific CellMon using the LED
How to wire up the RC7S CellMon mounting kit
How do I connect BlockMons - Battery Pack chain
Any chance of adding additional resistors to the CellMons for extra discharging/balancing?
Shunt
How to connect the ShuntMon2 to Watchmon4 supervisor
How to connect the shunt SPF102MOD to the WatchMon
Can we use our own Shunt Block?
PIN code
Where do I find the PIN code?
Snapshot report
Generating, extracting and understanding the Snapshot capture report
Software
Link to WatchMonToolKit main page
Understanding the status icons of the WatchMon Toolkit
Enabling Software & Firmware Beta Tester option
How to verify that the WatchMon software is the latest release
How to customise the theme / style of WatchMon toolkit
Are other Language alternatives available?
Can I just buy the WatchMon ToolKit software?
Inverters & chargers
How to control a SMA Sunny Island inverter/charger with a WatchMon
How to control a SolaX hybrid inverter/charger with a WatchMon
How to control a Victron Color Control GX with a WatchMon
How to control a Victron Venus GX with a WatchMon
How to control a Redback smart hybrid inverter/charger with a WatchMon
How to control a Brusa NLG5 charger with a WatchMon
How to control a Brusa NLG6 charger with a WatchMon
How to control a TC/Elcon charger with a WatchMon
How to control a Eltek Flatpack2 charger with WatchMon
How to control a EnPower charger with a WatchMon
Circuit Breaker Wiring Diagram
Schneider Electric - Circuit Breaker Voltage release tripping unitElectronic Auxileries -  Schneider Electric - Double Pole Circuit Breaker 125A 15kA
How to Connect a Circuit Breaker to Onboard Output/Input WatchMon4
How to connect the WatchMon4 to the Schneider Electric Circuit Breaker
Schneider Tripping Unit - product page
Schneider Circuit Breaker 125a 15ka - product page
Fan / Contactor Wiring Diagram
How to Connect a Fan to On-Board Output WatchMon4
How to Connect a Contactor to On-board Output WatchMon4
How to Connect a Positive Switch Latching Contactor to Expansion Board
Wiring / Screw Terminals
Screwdriver for Pluggable Screw Terminals - Starter Kit
Best practice for screw terminals
General WatchMon links
Why do I need a Starter Kit and not just the CellMons or WatchMons
How to outline your BMS requirements
Can I get extra support or troubleshooting during installation?
__________________
