How to connect to WatchMon via WiFi access point
Steps to remotely connect to the BMS via wifi router / access point. Caution the system will only be in display mode to ensure a safe connection. To make changes to the system will require the technician connect via USB.
Step 1 - Navigate to system connection selector and click
Step 2 - Navigate to Network tab
Step 3 - Select SystemID from available option (either click or enter number)
Step 4 - Close connection dialogue once system is connected and Active
Step 5 - Normal responding screens
Troubleshooting
If there is a software/ firmware mismatch the following will be displayed. There is a firmware upgrade process documented below.
