How to control a Eltek Flatpack2 with WatchMon
Eltek Flatpack2 HE48V-2000W
Here are the steps to configure the Eltek Flatpack2 2000W 48V HE Power Supply/Rectifier to the WatchMon supervisor.
CAUTION:  Example shown is for a demo LiFePO4 cell pack 16S1P, ensure that you adopt suitable values to your application and comply with the battery suppliers recommendation.
Step 1 - Install communication cable to charger via CAN port on WatchMon.
Step 2 - Initial rear view of Eltek Flatpack2 without connector socket
Eltek Flatpack2  rear
 Step 3 - Install canbus communication cable with twisted (~10 per 10cm)
 Eltek flatpack2 with canbus wire attached
Step 4 - Install AC power plug
Eltek Flatpack install AC plug
Step 5 - Install Anderson DC battery plug
 Eltek Flatpack2 - add battery connector
Step 6 - Install 120 canbus terminating resistor
Eltek Flatpack2 connector attach terminating resistor
Step 7 - On bottom pcb cover the resistor and terminal pins with hot glue
Eltek FlatPack2 - coating to pcb
Hot glue does not substitute appropriate insulation below this pcb.
Step 8 - Finished assembly
Eltek Flatpack2 Finished assembled
NB: Rectifier should have additional enclosure added to meet relevant compliance.
Step 9 - Navigate to Hardware and then Integration tab.
Step 10 - Select Canbus protocol to "Eltek FlatPack2 HE2000/48" and Save.
Eltek Flatpack2 Hardware Comm setup screen
Step 11 - Navigate to Control Logic, then Charging tab.
Step 12 - Adjust the charging control logic to suit the application.
  • Limited power must be enabled.
  • When the bypass current for all cellmons is above Final the system will complete charging cycle.
Step 13 - Navigate to Hardware, then CellMon tab.
Step 14 - Adjust the CellMon bypass voltage to suit the application.
Note: Make sure to "Device Sync" the changes to the CellMons.
Step 15 - Navigate to the Remote tab on the Control Logic screen.
Step 16 - Adjust the remote charging target to suit the application.
Remote Setup for Eltek Flatpack2
  • Scaling must be 100 for voltage.
  • Scaling must be 100 for current.
  • Maximum charging rate of rectifier is 42A
Step 17 - Navigate to Telemetry, then Live Stats to observe system operation.
Step 18 - Navigate to Control, then Remote to observe inverter info received
Eltek Flatpack2 - remote control setup
  • Charge Target Voltage - voltage cutout sent to inverter when charging
  • Charge Target Current - ampere limit sent to inverter when charging
  • Charge Actual Flags -  reported charging mode and operating state flag received from inverter
  • Charge Actual Voltage - charging cutout volatge setpoint sent from inverter
  • Charge Actual Current - reported battery amperes from inverter when charging
  • Charge Actual Power - reported battery state of charge SoC% received from inverter
  • Charge Actual Temperature - reported battery temperature from inverter
  • Discharge Target Voltage - voltage cutout sent to inverter when discharging
  • Discharge Target Current - ampere limit sent to inverter when discharging
  • Discharge Actual Flags - reported active message error flag received from inverter
  • Discharge Actual Voltage - reported battery voltage from inverter
  • Discharge Actual Current - reported battery amperes from inverter when discharging
  • Discharge Actual Power - reported relay state flag received from inverter
  • Discharge Actual Temperature - not used
  • Live statistics telemetry
Products used
Connector board for Eltek Flatpack2
