How to control a EnPower charger with a WatchMon
Adopting the EnPower charger can be configured as follows within the WatchMon supervisor. It may be necessary to run a BridgeConnect with the twin canbus ports running in pass-through mode to provide ground isolation from the charger traction battery supply and WatchMon ground reference.
CAUTION:  Example below has values shown for a demo LiFePO4 cell pack, ensure you adopt values suitable to your application.
Step 1 - Install communication cable to charger via CAN1 port on WatchMon.
NB: Add 120ohm terminating resistor on WatchMon pin 5 & 6.
Step 2 - Install communication cable to EnPower charger wiring socket.
NB: Add 120ohm terminating resistor on charging lead.
Step 4 - Select Canbus protocol to "EnPowerCharger" and Save.
  • Low power must be enabled.
  • When the bypass current for all CellMons is above Final the system will complete charging cycle.
Note: Make sure to use "Device Sync" to send the changes to the CellMons.
  • Scaling must be 10 for both voltage and current.
  • Low power current should suit the bypass capability of the CellMon.
  • The charger voltage target needs to be sufficient for all cells to reach bypass threshold.
Step 11 - Navigate to Telemetry, then Live Stats to observe system operation.
Additional useful screens to monitor include:
  • Node Chart.
  • Charging logic control.
  • Remote logic control.
  • Live Statistics telemetry.
Understanding the WatchMon - Node Chart
