How to control a SolaX hybrid inverter/charger with a WatchMon
Here are the steps to configure the SolaX hybrid inverter/charger to the WatchMon supervisor.
CAUTION:  Example below has values shown for a demo LiFePO4 cell pack, ensure that you adopt values suitable to your application and comply with the battery suppliers recommendation.
Please be advised that for a number of reasons some of our customers have switched to different inverters after their purchase.
Step 1 - Install communication cable to charger via CAN1 port on WatchMon.
WatchMon1  (same procedure as the WatchMon4 but the screw-terminal / connector looks different). Add 120ohm terminating resistor on WatchMon pin 5 & 6.
Step 2 - Install communication cable to Solax BMS socket (extract from Solax manual)
Typical Cat 5 cables have a different colour pin combinations to Solax manual.
Solax RJ45 pin 1 (typically Green/White) connects to Can-H WatchMon
Solax RJ45 pin 2 (typically Green) connects to Can-L WatchMon
NB: Using a CAT5 ethernet cable strip back the cable and connect to pins identified above.
Step 4 - Select Canbus protocol to "SolaxPowerSK" and Save.
  • Low power must be enabled.
  • When the bypass current for all cellmons is above Final the system will complete charging cycle.
Note: Make sure to "Device Sync" the changes to the CellMons.
  • Scaling must be 10 for both voltage and current.
Step 11 - Adjust the remote discharging targets to suit the application.
  • Do not run low power mode on discharging tab.
  • Control logic discharge voltage cutout should match the remote target.
Step 12 - Navigate to Telemetry, then Live Stats to observe system operation.
  • Live Statistics telemetry
