How to control a TC/Elcon charger with a WatchMon
Adopting the TC/Elcon charger can be configured as follows within the WatchMon supervisor. It may be necessary to run a BridgeConnect with the twin canbus ports running in pass-through mode to provide ground isolation from the traction battery supply and WatchMon ground reference.
CAUTION:  Example below has values shown for a demo LiFePO4 cell pack, ensure you adopt values suitable to your application.
Step 1 - Install communication cable to charger via CAN port on WatchMon.
Step 2 - Install communication cable to TC/Elcon charger wiring socket.
NB: Add 120ohm terminating resistor to charging plug.
Step 4 - Select Canbus protocol to "ElconTcCharger" and Save.
  • Low power must be enabled.
  • When the bypass current for all CellMons is above Final the system will complete charging cycle.
Note: Make sure to "Device Sync" to update the changes to the CellMons.
  • Scaling must be 10 for both voltage and current.
Step 11 - Navigate to Telemetry, then Live Stats to observe system operation.
  • Live States telemetry
