How to control a Redback hybrid SH5000 inverter/charger with a WatchMon
Here are the steps to configure the Redback smart hybrid SH5000 inverter/charger to the WatchMon supervisor.
CAUTION:  Example below has values shown for a demo LiFePO4 cell pack, ensure that you adopt values suitable to your application and comply with the battery suppliers recommendation.
Step 1 - Install communication cable to charger via CAN1 port on WatchMon.
Step 2 - Install communication cable to Reback BMS socket (extract from  manual)
Typical Cat 5 cable colour pin combination.
Redback RJ45 pin 7 (typically Brown/White) connects to Can-H WatchMon
Redback RJ45 pin 8 (typically Brown) connects to Can-L WatchMon
Redback RJ45 pin 1 (typically Orange/Green) connects to WatchMon GND
NB: Using a CAT5 ethernet cable strip back the cable and connect to pins identified above.
Step 4 - Select Canbus protocol to "Redback Hybrid SH5000" and Save.
  • Low power must be enabled.
  • When the bypass current for all cellmons is above Final the system will complete charging cycle.
Note: Make sure to "Device Sync" the changes to the CellMons.
  • Scaling must be 10 for both voltage and current.
Step 11 - Adjust the remote discharging targets to suit the application.
  • Do not run low power mode on discharging tab.
  • Control logic discharge voltage cutout should match the remote target.
Step 12 - Navigate to Telemetry, then Live Stats to observe system operation.
  • Live Statistics telemetry
