Understanding the status icons of the WatchMon Toolkit
A number of key status states can be found in the bottom left corner of the Toolkit application, when hovering over the icon a text explanation is available. If you click the icon this will navigate to the screen to resolve or investigate the issue.
Individual status icons and the relevant meanings:
  •  No Connection -  Application is not linked to WatchMon supervisor.
  •  Heart-beat blinking - confirms that the system is linked to WatchMon supervisor.
  •  Link-Wifi connection link via Wifi
  •  Link-USB connection link via USB, will enable system modifications
  •  Discharge-Normal System is Ok to discharge at normal/high power mode.
  •  Discharge-Limp System is in limited power for over discharge mode.
  •  Discharge-Off System has disabled discharging.
  •  Charge-Normal  System is Ok to recharge at normal/high power mode.
  • Charge-Limp System is in limited power mode to suit bypass balancing.
  •  Charge-Off System has disabled charging.
  •  Charge-Complete state has reached fully charged and in idle full mode.
  • Critical Fault system has disabled battery isolator/contactor.
  • Heating On control for heating has been triggered.
  •  Cooling On control for cooling has been triggered.
  •  New Software available for download and upgrade.
  •  New Cellmon Firmware available for hardware device / modules found in the system.
  •   USB Powered supervisor with 5V supply from USB no supply pins
  •   Auto balance running from cell extra bypass mode
  •   Toolkit logging running from software app
  •  Configuration synchronisation task required.
  •  Bypass testing has not been verified.
  • Charge-Heat Relief has been evoked, trigger charging to be paused until bypass cool down
  •  Setup Wizard has not be run on this supervisor
  •  CellMon Network needs to be verified.
  •  Configuration wizard has not been finalised.
  •  Low Supervisor Voltage has been reported (critical supply), typically less than 9v.
  •  Firmware Update available to the Watchmon supervisor
  •  Read Only mode from the supervisor
  •  High Temperature Alert from cell monitors
  •   High Voltage Alert from cell monitors
  •   Low Voltage Alert from cell monitors
