Understanding the WatchMon - Control Logic - Thermal settings
Administrative screen for the WatchMon supervisor hardware, and how to understand the various fields available to configure the thermal (heating /cooling) control logic.
Navigate to this screen via the Control Logic option on the Menu then choosing the Thermal tab. Editing only available when in Technician mode.
Cooling Mode: operating mode for the cooling control logic.
  • Auto will adopt the state calculated based on thresholds specified.
  • ManualOn - will for the system state ON.
  • ManualOff - will force the system state OFF.
Hi Cell Celcius (CT5):  Cell temperature threshold that is OK to operate, if above will start the cooling control when monitoring is enabled.
Hi Ambient (BT5):    WatchMon supervisor temperature threshold that is OK to operate, if above will start the cooling control when monitoring is enabled.
In Bypass:  when monitoring is enabled will start the cooling control if any cellmon modules goes into bypass.
Delay transition - Stop: Ensures that the state change from ON to OFF must exceed beyond the period specified in seconds.
Delay transition - Restart: Ensures that the state change from OFF to ON must exceed beyond the period specified in seconds.
Heating Mode: operating mode for the heating control logic.
Lo Cell Celcius (CT4): Cell temperature threshold that is OK to operate, if below will start the heating control when monitoring is enabled.
Lo Ambient (BT4):  WatchMon supervisor temperature threshold that is OK to operate, if below will start the heating control when monitoring is enabled.
Setup RX: Flashes when setup configuration is received (hover over will display time received).
Edit: This button opens up fields to editing, only available when in Technician mode.
Save:  Saves values into system and returns to read only mode.  This only works when connected by a USB.  If saving whilst connected via WiFi the following Error message appears.
Default:  Restore values to default.
Pressing the Edit button will make the options UNDO - SAVE and DEFAULT buttons available
