Administrative screen for the WatchMon supervisor hardware, and how to understand the various fields available to configure the hardware integration settings.
Navigate to this screen via the Hardware option on the Menu then choosing the Integration tab. Editing only available when in Technician mode.
In edit mode:
  1. Change the Canbus mode to the appropriate external connecting system.
  2. Save.
Canbus: Settings include an ON/OFF broadcast switch and an active light as well as the ability to choose the protocol from a list.
Wifi:  Settings include an ON/OFF broadcast switch and an active light as well as the ability to choose the protocol from a list.
USB:  Settings include an ON/OFF broadcast switch and an activity status.
Setup RX: Flashes when setup configuration is received (hover over will display time received).
Edit: This button opens up fields to editing, only available when in Technician mode.
Save:  Saves values into system and returns to read only mode.  This only works when connected by a USB.  If saving whilst connected via WiFi the following Error message appears.
Default:  Restore values to default for Integration settings.
