Understanding the WatchMon - Hardware configuration - Shunt SoC% settings
Administrative screen for the WatchMon supervisor hardware, and how to understand the various fields available to configure the hardware Shunt State of Charge settings.
Navigate to this screen via the Hardware option on the Menu then choosing the Shunt tab. Editing only available when in Technician mode.
In Edit mode:
  1. Specify the battery capacity Ah.
  2. Save.
Shunt Type:  The type of shunt used can be selected.
Nominal Capacity:  Nominal capacity in Ah.
Reverse orientation:  ON/OFF switch regarding the orientation of the batteries
Idle Current Threshold - Charge:  Low Threshold for idle current when charging, only available in advanced mode.
Idle Current Threshold - Discharge: Low Threshold for idle current when discharging, only available in advanced mode.
Re-Calibrate in Bypass:  ON/OFF to allow reset of SoC% to Full if going into Bypass. Only available in advanced mode.
Re-Calibrate Low SoC:  ON/OFF to allow reset the State of Charge back to empty (0%) if it goes below this value. Only available in advanced mode.
Re-Calibrate Hi SoC:   ON/OFF to allow reset the State of Charge back to full(100%) if it goes above this value. Only available in advanced mode.
Empty SoC% cycle threshold:  Threshold of State of Charge that when goes below and returns to full will count towards a discharge cycle.  Only available in advanced mode.
Full SoC% cycle threshold:  Threshold for State of Charge that when goes above from empty threshold will count towards a discharge cycle.  Only available in advanced mode.
Voltage:  Current shunt sensor reading for Voltage.
Current:  Current shunt sensor reading for Current.
State of Charge:  Current state of charge.
Celcius:  Current shunt sensor reading for Temperature.
Serial Number:  Serial number of Shunt module.
Ticks: Communication activity with shunt module related to RX / TX traffic.
Recent Consumption:  Recent Nett position in Ah.  Seen also in Metrics.
Daily Session Total:  Daily charge and Discharge amounts in Ah.
Capacity Remaining:  Capacity till Full and Empty.
Time Remaining:  Duration at current levels till full or empty.
Setup RX: Flashes when setup configuration is received (hover over will display time received).
Registers:  Brings up Registers dialog.  Many of the items available using the Metrics button can be accessed here too.
Volt Ratio:
Current Ratio:
Energy Ratio:
Thermal Ratio:
Accumulation:  Nett position of Accumulation Counter.
Capacity:  Capacity of Accumulation Counter
Manufacture Code:  Manufacture Code of Watchmon.
Part Number:  Part Number.
Version Code:  Version Code of firmware.
PNS:
Edit - This button opens fields to editing, only available when in Technician mode.
Save:  Saves values into system and returns to read only mode.  This only works when connected by a USB.  If saving whilst connected via WiFi the following Error message appears.
Default:  Restore values to default for Shunt SoC% settings.
Advanced:  Allows editing of more advanced fields.
Metrics:  Brings up Metrics screen.
Metrics dialog
Navigate to this screen via the Metrics button on the Shunt screen.
Nominal Capacity:  Bought through from main screen.
Accumulation Counter:  Counts usage including Nett position, Charge and Discharge.
State of charge:  Available to edit with Update, Full and Empty buttons available.
SoC Cycles:  Available to edit with Update button.
Pressing the Edit button will make the options UNDO - SAVE - DEFAULT - ADVANCED and METRICSbuttons available.
  Support Tip:  Pressing this button calls up the knowledge base on this screen.
