Understanding the WatchMon - Hardware configuration - System settings
Administrative screen for the WatchMon supervisor hardware, and how to understand the various fields available to configure the hardware system settings.
Navigate to the screen via the Hardware menu option and choosing the System tab. Editing only available when in Technician mode.
In edit mode:
  1. Name the system so easy to find on the network.
  2. Save.
  3. Sync the clock.
System ID:  Number identifier of the system, only editable in Advanced mode.
System Code:  Short code given to the system (length 7 chars).
System Name:  Name given to the system (length 19 chars).
Asset Code:  Asset number given to the system (length 19 chars).
Preset:  Preset number, only editable in Advanced mode.
Hub:  Hub identifier, used for clusters of multiple supervisors, only editable in Advanced mode.
Hardware Version:  Hardware version of the connected supervisor.
Firmware Version:  Firmware version of the connected supervisor.
Serial Number:  Serial number of the WatchMon supervisor.
Supply:  Current supply voltage reading on the WatchMon supervisor (pins 1 & 2).
Ambient:  Current temperature sensor reading on the WatchMon supervisor.
Startup Time:  Time recorded when the WatchMon supervisor was last powered up.
Device Time:  Current clock time from WatchMon supervisor.
Computer Time:  Current clock time on computer.
Sw Version:  Software Version on the WatchMon.
Setup RX: Flashes when setup configuration is received (hover over will display time received).
Time Sync:  Process to synchronise the clock in the WatchMon supervisor to the computer time.
Factory Reset:  Process to reset the WatchMon supervisor back to factory settings, the Shunt and Lifetime metrics need to be reset separately.
Reboot System:  Process to restart the WatchMon supervisor. This should be done with care as any peripheral equipment may experience disruption when the system resumes.
Hardware Admin:  Admin features with appropriate authorisation.
Edit:  This button opens up fields to editing, only available when in Technician mode.
Save:  Saves values into system and returns to read only mode.  This only works when connected by a USB.  If saving whilst connected via WiFi the following Error message appears.
Default:  Generate a new system ID, code and restore values to default for System settings.
Advanced:  Allows editing of more advanced fields.
Pressing the Edit button will make the options UNDO - SAVE - DEFAULT and ADVANCED buttons available and make the System Code, System Name and Asset Code editable
  Support Tip:  Pressing this button calls up the knowledge base on this screen.
