Understanding the WatchMon - Telemetry - Lifetime Telemetry
Administrative screen for the WatchMon supervisor hardware, and how to understand the various fields available to read the telemetry information over the WatchMon supervisor hardware's lifetime.
Navigate to this screen via the Telemetry option on the Menu then choosing the Lifetime tab.
Review the total number of occurrences and the recent times when control states change from ON to OFF, etc..
System Startup:  Total number of events when the system has been started / powered.
Daily Sessions:  Total number of daily session recorded.
SoC% Total cycles:  total number of cycles where the battery SoC% state of charge has cycled from full to empty and returned to full threshold.
Critical BAttOK - count:  Total number of events when the Critical BattOK is enabled.
Critical BattOK - ON time:  Most recent time when critical BattOK control was enabled.
Critical BattOK - OFF time:   Most recent time when critical BattOK control was disabled.
Charge On - count:  Total number of events when charge high power control is enabled.
Charge On - ON time:  Most recent time when charge control was enabled.
Charge On - OFF time:  Most recent time when charge control was disabled.
Charge LimPower - count:  Total number of events when charge low/limited power control is enabled.
Charge LimPower - ON time:  Most recent time when charge control was switched to low/limited power.
Discharge ON - count:  Total number of events when the discharge high power control is enabled.
Discharge ON - Recent ON time:  Most recent time when control was enabled.
Discharge ON - Recent OFF time:  Most recent time when control was disabled.
Discharge LimPower - count:  Total number of events when Discharge low/limited power control is enabled.
Discharge LimPower - ON time:  Most recent time when discharge control was switched to low/limited power.
Thermal Heat On - count:  Total number of events when thermal heating control is enabled.
Thermal Heat On - ON time:  Most recent time when thermal heating control was enabled.
Thermal Heat On - OFF time:  Most recent time when thermal heating control was disabled.
Thermal Cool On - count:  Total number of events when thermal cooling control is enabled.
Thermal Cool On - ON time:  Most recent time when thermal cooling control was enabled.
Thermal Cool On - OFF time:  Most recent time when thermal cooling control was disabled.
Startup Time:  Most recent Time when system started / power up.
First Sync Time:  Time when the CellMon modules were first syncronised to the configuration.
Initial Bypass:  Time when cell first went into bypass for the first time on the day.
Bypass Completed:  Time when all CellMons achieved final bypass for the day.
Bypass Test:  Time when last Bypass Test was completed.
Bypass Outcome:  Outcome of last Bypass test.
SoC% Empty state:  Most recent time when the state of charge went below the empty threshold.
SoC% Full state:  Most recent time when the state of charge went above the full threshold.
SoC% Re-Cal Empty:  Most recent time when the state of charge triggered a recalibration event on empty.
SoC% Re-Cal Full:  Most recent time when the state of charge triggered a recalibration event on full.
Reset Lifetime Metrics:  Ability to reset the lifetime statistics, only available in technician mode.
