Understanding Tools - Bypass Tester - Results
Results screen for the WatchMon supervisor hardware, and how to understand the various fields available for Results of a Bypass Test.
This screen is accessed via the Hardware option on the Menu, then choosing the CellMon tab and pressing the Bypass Tester link and on the Results Tab.
To view the results of the Bypass test once it has been completed.  This screen shows the data for all cells being tested.
ID:  Node ID for the CellMon.
Test Date:  Test Date that the Bypass test occurred for the CellMon in Bypass for the Node.
Test Time: Time of Day that the Bypass test occurred for the CellMon in Bypass for the Node.
Bypass Duration: Length of time in seconds of the CellMon in Bypass for the Node.
Test Outcome:  Pass or Fail of the CellMon in Bypass for the Node.
Initial:  Initial temperature of the CellMon in Bypass for the Node.
Final: Final temperature of the CellMon in Bypass for the Node.
Action Button/ Process link events
Start: Starts bypass test.  Available when Bypass test not in progress.
Stop: Stops bypass test.  Available whilst Bypass test in progress.
Advanced:  Allows editing of more advanced fields.
