Upgrading the Watchmon4 firmware
Make sure you update to the latest WatchMon4 firmware, this is a very important procedure.
Caution:  Make sure that external peripheral systems will be ok when the system restarts. The system will go offline and then re-start, if there are critical contactor devices that must remain energised additional measures must be made by you to prevent the disruption of power.
Step 1 - Go to the Tools Menu
Step 2 - Press the Firmware updater button.
Step 3 – Select the device firmware you would like to update, in this case “WatchMon4” highlighted in red
Step 4 - Run the upgrade process.
This window will pop up showing the download in progress
Step 5 – The WatchMon4 Firmware has been updated successfully. Click on “Toolkit” this will close the window and start ToolKit software.
Troubleshooting
No response from WatchMon4 hardware
Related References
Running the Wizard setup to define your system
How to connect the Cell monitors to WatchMon4 supervisor
Where do I find a pincode?
