Watchmon4 hardware guide and pin assignment
BMS central processor for watching cell monitoring units and provides supervision functions. The WatchMon4 supervisor is able to notify remote systems (inverter/charger) of the battery state and when required trigger evasive action to prevent damage to battery pack.
Remote Communication
  • WiFi connectivity (normal, disabled, or read only)
  • Can-Bus communication port to remote systems
  • Modbus rs485 link allowing connectivity to inverters without canbus
  • optional blue-tooth connectivity (future enhancement)
Built-in input and output control
  • two (2) onboard FET outputs 4A with 8A inrush
    • e.g. remote circuit breaker trip + fan
  • two (2) onboard input
    • e.g. circuit breaker trip sensor
Added features and I/O with Expansion board
  • 5 Digital inputs
  • 2 Analogue inputs
  • 1 Pulse counter input
  • 8 Digital outputs  (4 FET + 4 Relay)
  • 2 Digital output PWM
  • NeoPixel LED control
    Power Input
    • Built-in 8v to 65v DC-DC supply
    • handle automotive transients
    Processor
    • ESP32 more powerful than WM1
    • Data logging of key metrics for 10 years
    • Clock with backup battery
    • optional over the air (OTA) upgrades to firmware
    • upgrades firmware via USB
    • secure web encryption to allow SSL link when connecting to optional cloud portal via MQTT.
    • prevent all outputs from resetting when the processor firmware is updating (no transient on/off/on)
    BMS Module Connectivity
    • serial link to SoC% current sensor module
    • serial link to isolated CellMon modules
    Ease of Use
    • pluggable screw terminals to simplify installation, allowing pre-made cables for both shunt and cellmons
    • relocation of onboard temperature sensor away from heat sources to have better representation of ambient conditions
    • finger guard cover clip slots, more coming soon
    • intuitive screw terminal labeling to reduce need to check documentation
    How to Connect a Circuit Breaker to Onboard Output/Input WatchMon4
    How to connect the WatchMon4 to the Schneider Electric Circuit Breaker
    _______________________
