Wifi troubleshooting
There are two different ways to connect to your WatchMon via Wifi:
  1. Connecting the WatchMon4 to your router and accessing wirelessly via Wifi
  2. Connecting your computer directly to the WatchMon4's Wifi
Here is a link showing both methods: connecting-watchmon4-via-wifi
Try a both and see if you you notice that one connection is more reliable than the other.
Restart your router
If the problem persists, just like any other wifi device experiencing connection issues, it is a good idea to turn both your router and the WatchMon4 OFF for a at least 10 seconds and back ON again. Most cases restarting both devices fix the issue.
Distance from the router
Running the WatchMon too far away from your Wifi router would also cause a poor connection
Weak Wifi coverage
It is a good idea to use another device such as laptop or smartphone to check the wifi signal strenth at the WatchMon's location. Sometimes the devices may show as "connected" but if its signal is "poor" or "weak" then you need to improve the wifi coverage to avoid unstable / dropping connection.
Wifi repeater
You might need to add a wifi repeater halfway between the 2 locations. They are very easy to install and fairly cheap nowadays. Link for wifi repeater
Place the repeater between the router and the WatchMon where both devices can talk/connect to the repeater.
Wifi signal vs Walls and windows
It is important to consider what physical barriers are between the router and the WatchMon.
If your battery system is located at the basement, garage, under or in a separate room outside the house/business, you definitely should consider a repeater as the wifi signal would be very weak through multiple walls / concrete floor.
WatchMon protective 3D cover
Do not remove the 3D cover, it shouldn't compromise performance or cause the processor to overheat. We have tested these devices for months in very different environments before releasing the product to the public.
Connecting the computer directly to WatchMon's Wifi
Direct connection between your computer and the WatchMon's wifi without connecting through a router should be more reliable and resolve weak wifi signal issues. The downside is that in this mode your computer is no longer connected to the internet.
Consider USB cable connection
There are many different scenarios and conditions to consider when connecting via wifi, weak signal or "wifi dead spots" are the most common cause of problems. USB cable still the most reliable and stable connection option.
Connecting to WatchMon4 via Wifi
