How to install the WatchMon Toolkit software
It is recommended that "WatchMon Toolkit" software be installed on a Windows 10 pc. Batrium will provide backward compatibility to Windows 7 desktop or later, but will not support older operating systems such as Windows XP or Vista. The prerequisite for Microsoft .Net framework 4.5.2 or later is required, the installer will examine your system and prompt you to upgrade/install if not found.
The installer includes the separate installer for the "Teensy USB serial driver", this driver enables the connection to the WatchMon hardware.
The installer will automatically upgrade over the existing version.
Step 1 - Download the latest software using the following link WatchMonToolkitInstaller_1.0.30.msi
Step 2 - Start the installation.
Step 3 - Accept running in Admin mode.
Step 4 - Installing will run though its status of steps and complete.
Step 5 - Completion and finish of installer.
Step 6 - "WatchMon Toolkit" programs will appear in Start Menu and icon on desktop.
Step 7 - Only run the first time "Teensy USB Installer".
Step 8 - Accept "USB Driver" to run in Admin mode.
Step 9 - Start USB Device Driver install and monitor status.
Step 10 - Run new program "WatchMon Toolkit".
On completion the next run through commission sequence
How to sync the CMU cellmon configuration with a WatchMon
When upgrading software this will also be the need to upgrade the firmware on the WatchMon
How to upgrade the Watchmon firmware
