Simplified firmware upgrade of the Watchmon
Caution  Make sure that external peripheral systems will be ok when the system reboots. The system will go offline and reboot, if there is a critical contactor that must remain energised additional measures must be made by you to prevent the disruption of power.
 Step 1 - Go to the Tools Menu
Step 2 - Press the Firmware updater button.
Step 3 - Run the upgrade process.
A separate console program will open and start uploading to Teensy
Step 4 - Monitor that the program complete 100% successfully.
If SUCCESS close and start Toolkit.
Notes
  • If any problems occur repeat after powering down and up the WatchMon (both USB and power should be removed.
  • Each version of firmware has a relevant version of software for the toolkit. When changing the firmware make sure you also do the necessary upgrade/retrograde to the "Toolkit" software.
  • If device does not respond press BOOT/PROG on WatchMon to manually enter Program Mode.
