Which PC / Tablet to purchase
Devices such as the attached "low-spec" Windows 8.1 tablet will happily run the software. When purchased with OS license for approx AUD$130. Always look for high specification as will give a better responsive environment.
Our system does require the full versions of windows rather than RT or IoT versions that are sometimes used when loading onto a MacBook or mobile device as these were cut down versions of windows.
BmsSuite has been designed with a minimum screen resolution of WSVGA 1024 × 600 pixels. To connect to the hardware supervisor (PacMon / SiMon) will require a USB 2.0 port. Network access using Wifi will enable remote access and connect the telemetry to cloud logging.
Specification  (approximately AUD$130)
  • Display Size - 7.0 Inches
  • Resolution - 1024 x 768 Pixels
  • Processor - 1.33 GHz
  • RAM - 1GB
  • SSD Storage - 16GB
  • Webcam, Bluetooth, WiFi
  • 1 x USB 2.0 Ports
  • separate recharge port
Additional
  • Mini USB Keyboard (recommend USB rather than bluetooth)
Typical requirement
  • Microsoft Windows 8.1
  • .NET Framework 4.5.1
  • 2 x USB ports
Minimum requirement
  • Microsoft Windows 7
  • .Net framework 4.0
  • 1 x USB ports
